Disregard this. I didn't read your post correctly. Same MAFV from 5-7k is weird. Even with how my system cuts over to the SS controller it shows the correct MAF V. Air flow in g/s is what is locked in after a certain point.
a .1 or .2 increase in MAF V up top is a humongous increase in air flow. That's not a linear increase from 0-5.Sorry maybe I exaggerated, it does increase slightly. But MAF V is the actual measure of airflow, since only the transfer function is modified in the ECU when you add the split second controller.
Here is a little excerpt:
You don't have much timing in that thing yet. You have cams right? I'll have to get a log of my flow numbers, but not all things are equal in that either with elevation differences and stuff.
Stock cams, no headwork? That's why the EFR ain't makin what it should be most likely.
You can go bigger turbo, sure, but unless you increase the overall VE of the engine, well, you're still trying to run a horse through a doggie door.
Well shit, now I'm gonna have to overnight some cams and install them over the weekend rofl. Would there be much benefit to moderately aggressive cams without porting the exhaust side of the head?
Just remember that even with cams and headwork you're not gonna get to 600, but I'm assuming you already bought the 5558. I'm interested to see the flow/power difference with cams as the only difference. This is really validating my build for me lol.
Make sure you test with the same spring pressure, though the EWG is already going to flow more up top.
If you were looking for more top end why not do a 5862dbb? You would get the head room you want and I bet spool is very similar to the 5558dbb.
Gen 2 5558dbb in green
VS gen 1 5862 JB in yellow,
In case you're curious. View attachment 11971
Yellow was my ms3. Green is an ms6 on e50
Power is way low on the 5558, but that may be an issue with that car itself
