DISI-MZResponse 2.0
  • Watchers Watchers 23
That's interesting....
Edit: would still be a pain in the ass because at least one of them would still have to be installed the wrong way and fixed with a nut underneath (that has no clearance for a lock washer or anything)... That's also the only one that's still on the car.
Miatas have the same issue with heat expansion pushing the studs out. My car does it. I have to retorque the exhaust manifold nuts every few oil changes.
Whenever I get around to putting the bigger turbo on I was gonna install new studs and nuts such as those. Seems to be the best way to fix it.
Funny thing about lock washers. They don't provide any actual locking force.
Use red locktite and torque
I'd try the lock washer stud fix I suggested before buying a whole new setup. Unless you want an excuse to upgrade which no one will complain about besides your wallet.
Your right, I forget which one is for high heat
You're
What I'm more worried about is this happening again at one or more of the corners. Again, I don't really want to clearance everything as it's all ceramic coated, plus I'd have to get into the weld at the flange on more than one corner. I also really, *really* don't want to have to retighten stuff every so often, which is why I'm leaning towards the vband option.
Maybe but I think it's worth a shot before you buy a bunch of new parts
As long as I can use PayPal for the bulk of it (6mo no interest) I'm gonna go new parts route.
I would have figured people would want me investing more money into the Speed, since doing so increases my chances of saying "fuck it" and doing a full rebuild.
Nobody likes a quitter. We need our cuddle buddy.
*Cough*
IMG_20230506_132300381_HDR.jpg IMG_20230506_132451384_HDR.jpg IMG_20230506_132339372_HDR.jpg IMG_20230506_132304271_HDR.jpg IMG_20230506_132457998_HDR.jpg
The exhaust valve stems on 1,2 and 3 were kind of ashy white, while the ones on 4 were black and looked like they had some burned oil buildup.
Is the exhaust manifold scorched? And the valve condition would point at four having the broken ringland and it would appear that the ringland took some of the turbo with it on the way to hell
Burned from overheating as in material discolored. If its soot that's ok since we know the gasket was missing
