Disi-MZResponse
  • Watchers Watchers 66
Status
Not open for further replies.
The 12.5:1 compression pistons (they'd be 14:1 on an otherwise stock block) are also lighter than stock by about ~20 grams IIRC.
Listen here, cocksucker: It ain't my fault Wiseco forgot how to charge a credit card. Anywho, I didn't say WHICH Tuesday.
Somebody's grumpy. I'll give your booty a tickle when I come down this weekend.
Set sail for boner harbor, full mast.
Some quick stats:
Stock:
Rod: 452g (no cap/bolts, not sure what full weight is)
Piston: 354g, 14cc dish
Wrist pin: 136g
Wiseco:
Piston: 350g, 8.9cc dome (that's just shy of +23cc piston volume, folks!)
Wrist pin: 137g (wrapped in plastic; probably 1g less)
Pauter:
Rod: 571g
For comparison:
Manley H beams are 599g
IMAG0606.jpg IMAG0607.jpg IMAG0608.jpg IMAG0609.jpg IMAG0610.jpg IMAG0611.jpg
Minor update:
Dropped off some goodies at the machine shop today; the crank, flywheel, pressure plate, and crank pulley are all getting balanced. The rods and pistons will be weighed and matched within reason, and the keyway will be milled down to fill the full key length but allow the unkeyed crank pulley to still fit perfectly.
Status
Thread viewers
