Wait you get canada day and American independence day observed off what is this sorcery
thanks for mentioning this! i am a LITTLE concerned they might move a little causing them to come loose but i did my best to secure the hoses so they literally cannot move lol. hopefully this covers it but maybe ill need to check on them after some driving.Just watched your video on the PCV plate / can install, I would double-check that your -10 fittings are staying put after putting on the 90 degree adapters. I had issues with mine after trying to put it together when the plate was on the car, rather than when it was off where the force from the hoses and the 90 caused it to work a few degrees loose due to the force it was exerting laterally.
Lmao. I can’t wait to finally have my fmic setup be not janky. Should do wonders for bats as well.Do you have a backup tune you can switch to that makes less power in case you are over?
And make sure to heatsoak the hell out of the intercooler
Yea the screamer pipe is REAL close to the Downpipe. Maybe 6” away or less. Plan is to just brace it to the Downpipe. This was also suggested by tial as a good place to go to. I’m not sure if I’ll get my buddy to do it or if I’ll ask the shop to do it while my intercooler is being reworked.Did you find a way to support the screamer pipe?
It might be gear oil. I thought maybe gear oil at first. But from where? I need to take a closer look around the shift selector I guess but I don’t think it’s coming from there.Pivot shaft seal? Sure it's not gear oil?
Oem oil light is lit up as well. If it was just my gauge I’d be ok but oem light on? That’s game over.Did you unplug the sensor while you were in there?
