Clintonicms3
Alright that makes a lot more sense! Thanks man you are the bomb. Yea whenever you get that drawing up that’ll be awesome! I’ll try to have this all ordered. So I probably don’t need to fab up anything for the return part just have it pour back in?In your case you would use the stock feed line and connect to the firewall just like I have but go to the HPFP instead of the regulator. And then from the regulator you would go back to the tank with a DIY return line. I can draw up a diagram tomorrow when I'm back at work (where I saved this file)
It's all the same bits, but different routing
Sent from my SM-G950U usin
[doublepost=1517786619][/doublepost]Also @Maisonvi did you have problems running your Bosch 630cc injectors? Or did they not flow enough? My goal is around 575 which is where my turbo will start to max out.
